• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mac » Hardware » late 2006 iMac airport
Page 1 of 2 1 2 >
Topic Options
Hop to:
#596640 - 06/17/13 11:38 PM late 2006 iMac airport
lanovami Offline
This space for rent
Loc: 東京都
So, after finally upgrading the memory on my late 2006 iMac, it has become clear that the airport is going bad. As I mostly just surf, I never notice much lag but the online game hound that is my son complains about it all the time. The 5 year warranty I had ran out a while back. Is it correct that to replace the airport extreme card, you have to get way up inside it? I am not doing that.
Are there products I can buy that I can attach to the outside of the computer through the USB to get the same effect? I've done some searching, but I like the definitiveness of the answers I usually get here. smile Thanks in advance.
We are what we repeatedly do - Aristotle
Top
#596644 - 06/18/13 01:34 AM Re: late 2006 iMac airport [Re: lanovami]
Reboot Online   content
Loc: Columbus OH
What kind of router do you have?
Go to speedtest.net, what kind of numbers, ping, down, and up?
Can you temporarily connect via Ethernet? Turn off airport if you do. What is speedtest like with Ethernet?
If it is the card, could be, it's doable. The hardest part is releasing the two latches at the top.
Take apart, click on Airport card. In the step where they have you insert a credit card, it's a PIA. I have never had the luck. I just pull the bottom open far enough to be able to get a screwdriver in to flip the latches at the top.
And yes there are external options but run the speed tests, let's see if it is the card, your connection in general...or the son. grin
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#596677 - 06/18/13 10:33 AM Re: late 2006 iMac airport [Re: Reboot]
lanovami Offline
This space for rent
Loc: 東京都
Thanks for your advice. Am doing some speed comparisons.
Top
#596678 - 06/18/13 10:42 AM Re: late 2006 iMac airport [Re: lanovami]
lanovami Offline
This space for rent
Loc: 東京都
Don't think I can do an ethernet check because my ethernet connection on my iMac has been next to useless for years now and I have been using only the aiport card. I decided to instead compare my iMac to my son's iPad.
I took two readings for each a few minutes apart.
iMac 1st reading: ping 11ms download 15.11Mbps upload 1.90Mbps
iMac 2nd reading: ping 12 ms download 3.01Mbps upload 0.97Mbps
iPad 1st reading: ping 18 ms download 18.57Mbps upload 1.85Mbps
iPad 2nd reading: ping 20 ms download 14.58Mbps upload 1.95Mbps
The second Mac reading (which was very near in time to the 2nd iPad reading) seems pretty conclusive maybe?
Top
#596679 - 06/18/13 10:45 AM Re: late 2006 iMac airport [Re: lanovami]
lanovami Offline
This space for rent
Loc: 東京都
My router? Um, not sure, but I could check. Regardless, the iPad and the iMac speeds are a useful comparison no?
Top
#596680 - 06/18/13 10:48 AM Re: late 2006 iMac airport [Re: lanovami]
lanovami Offline
This space for rent
Loc: 東京都
3rd test, done one after the other.
iPad ping 18 ms download 23.55Mbps upload 1.78Mbps
iMac ping 10 ms download 11.27Mbps upload 1.97Mbps
Top
#596699 - 06/18/13 08:19 PM Re: late 2006 iMac airport [Re: lanovami]
MacBozo Offline
Is the iPad at the same distance from the router as the iMac?
Top
#596702 - 06/18/13 09:20 PM Re: late 2006 iMac airport [Re: lanovami]
Loc: Columbus OH
The iPad numbers kind of vary. Is anyone else using the wireless at the time you run the speedtest?
Is it the same distance away when you run the tests and like Michael mentioned, are the iPad and iMac in the same room?
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#596707 - 06/18/13 10:01 PM Re: late 2006 iMac airport [Re: Reboot]
lanovami Offline
This space for rent
Loc: 東京都
No one else was using the wifi at the time.
And yes the iPad and the iMac were the same distance away. It is a time capsule I use by the way.
Top
#596713 - 06/18/13 11:54 PM Re: late 2006 iMac airport [Re: lanovami]
Loc: Columbus OH
Do you have a lot of networks around you? Set up the 5Ghz n network for the iPad and iMac. The iPhone needs 2.4 ghz though. If it is network interference going n may help it.
The big difference between the tests on the same device is odd. They will vary on Download by 1 or 2 maybe, but usually not the difference you had on the iPad.
Edited by Jim_ (06/19/13 12:07 AM)
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.047 seconds in which 0.024 seconds were spent on a total of 14 queries. Zlib compression enabled.
