Am I insane? #588898 01/25/13 12:17 AM
C
Calion Offline OP
C
So the time has finally come; NUDC's inability to sync with my iPhone has forced me to move. And I've moved to Now X.
Am I nuts? Is this an awful idea? I've been using NUD, and then NUDC, since 1992; my entire life is in there. Is there anything I should be aware of? I'm using Snow Leopard. Is Now X going to break when I move to Mountain Lion? Should I just forget it and buy BusyCal and limp along with Address Book (yuk)?
Most importantly, is there anyone who still knows anything about this product hanging around in case I run into trouble?
Re: Am I insane? [Re: Calion] #588922 01/25/13 04:43 AM
Reboot Offline
Move on, it's been dead for 3 years now. I'm sure 10.7 breaks it.
I doubt that. If you browse these NOW forums it's been ages since anyone has responded with anything helpful.
Re: Am I insane? [Re: Calion] #588941 01/25/13 02:41 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
With all due respect.. you knew they went out of business 3 years ago... what were you expecting?
Re: Am I insane? [Re: NucleusG4] #588944 01/25/13 04:42 PM
C
Calion Offline OP
C
I'm not *expecting* anything; I'm *hoping* I can make Now X work for me, and was wondering if anyone here was having success doing that.
Re: Am I insane? [Re: Calion] #588945 01/25/13 06:24 PM
Reboot Offline
Like I said above Calion, if you browse these NOW forums it's been ages since anyone has responded, much less with anything helpful. There are some alternatives to the product but you'll have to do the legwork and browse the posts, I can't give any specifics off the top of my head. I was never a NOW product user.
The fact that you even have it working with 10.6 is lucky. Again my suggestion is if you ever want to upgrade software and hardware you'll need to move to something else. The NOW forums were migrated here when the site closed. None of the regulars to the AppleCentral Forums use it. The NOW forums were put here just as a reference.
Sorry about your plight but you need to find an alternative if you ever want to upgrade the OS.
Re: Am I insane? [Re: Calion] #589254 01/29/13 02:10 AM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Sorry Calion. I have had software that was no longer supported.
Frustrating as all hell.
You're beating a dead horse.
Re: Am I insane? [Re: Calion] #592032 03/21/13 06:24 AM
C
cvbcvb Offline
C
Calion, yes you are insane. Now X is junk.
