#591171 - 03/05/1307:24 AMAirDrop stopped working on MBpro
steveg
Making a new reply.
Loc: D'OHio
I've been using AirDrop to txfr files back and forth btwn my Mini and MBpro. Much faster and easier than file sharing. I do this maybe once or twice a week. This morning, AirDrop would not launch on the MacBook.
When I double click the icon, instead of opening the AirDrop pane, it opens a duplicate finder window. Oddly enough, holding the Option key while double clicking the icon opens the pane and shows the Mini. However, the MB still doesn't recognize the Mini. I don't get the "Save" option on the MB, and the Mini tells me the connection failed.
Nothing system-wise has changed recently, except for this morning's Java update via Software Update. I applied that to both Macs, but since AirDrop still opens on the Mini, I assume I can rule out the Java update as a culprit. Some googling has turned up a few issues regarding connectivity, but nothing like the no-launch problem I'm experiencing.
I have repaired permissions, done fsck -f, and run DW. But still no joy.
#591179 - 03/05/1308:51 AMRe: AirDrop stopped working on MBpro
[Re: yoyo52]
steveg
Making a new reply.
Loc: D'OHio
The problem was, that for no reason I can pin down, AirDrop was never in the sidebar. Selecting it from the Go menu or via shift/command/R only opened a finder window which displayed available drives, and double clicking the AirDrop icon would open the pane. It was always like that on both machines, but just stopped today on the MB. Jim had me check AirDrop in the finder prefs, which placed it in the side bar, so now, regardless of how I access it — sidebar, Go, keyboard shortcut — the pane opens immediately.
Just one of those things that hide in plain sight.
