Thanks for the weekend work on the forums Neil... While you're at it, could you cut off that worthless fatty section at the bottom. The Now software support section...
#590398 - 02/20/1310:35 AMRe: Forum liposuction....
[Re: NucleusG4]
neil
Neil Ticktin
Loc: Westlake Village, CA
So, while you don't like the section -- it gets viewed by people. I'd rather not kill it -- it's at the bottom however, so it should be easy to ignore.
