Forum liposuction.... #590397 02/20/13 06:33 PM
NucleusG4 Offline OP
Master•Blaster
Master•Blaster
Thanks for the weekend work on the forums Neil...
While you're at it, could you cut off that worthless fatty section at the bottom.
The Now software support section...
Re: Forum liposuction.... [Re: NucleusG4] #590398 02/20/13 06:35 PM
neil Offline
Neil Ticktin
Neil Ticktin
So, while you don't like the section -- it gets viewed by people. I'd rather not kill it -- it's at the bottom however, so it should be easy to ignore.
Re: Forum liposuction.... [Re: neil] #590399 02/20/13 06:44 PM
Master•Blaster
Master•Blaster
OK... it gets viewed. But rarely ever posted to...
It's not a hindrance.
I keep collapsing the section but it comes back opened.
Re: Forum liposuction.... [Re: NucleusG4] #590438 02/21/13 04:10 AM
neil Offline
Neil Ticktin
Neil Ticktin
yeah -- kind of "read only" these days. that has it's purpose, however.
