Go to Settings/Photos and Camera, scroll down to Keep Normal Photo for the option to choose to keep both versions. I've found sometimes I like the Normal better than HDR. Usually the HDR is better though.
carp
Dino's are Babe magnets
Loc: Hawaii
Food is fantastic and the presentation is superb . I normally don't like Japanese restaurants because they are to pricey for what they serve . For example I used to go to Kabuki Japanese restaurant , their shrimp tempura is 20 bucks and you only get 3 pieces. <-- yiiikes. Doraku however the same 3 pieces are 15 bucks -> so a little more reasonable.
Plus Doraku gives me 50% off the entire tab , now thats the price range I like
