#588400 - 01/16/1304:52 PMRe: Can Older LCD iMacs and TV Handle Temp Changes?
[Re: carp]
Biggerfoot
I invented modding!
They are both the white 17" models. I have a newer 27" one at work and I never used a white iMac before. They actually look pretty decent in person although I like my newer model better.
Thanks. It is easy to forget that PPCs are what, at least 6-7 years old. The fact that my 2000 QuickSilver is still running 24/7 with only one hard drive failure during this time is amazing.
#588652 - 01/21/1305:43 PMRe: Can Older LCD iMacs and TV Handle Temp Changes?
[Re: Biggerfoot]
Biggerfoot
I invented modding!
The final test piece is in place.
I had an extra LG 32" LCD TV that ended up fitting just right. Tonight and the next couple of days will be a great test as it will be around zero each night with the room probably getting down to 40 or so with the heat off.
#588654 - 01/21/1306:29 PMRe: Can Older LCD iMacs and TV Handle Temp Changes?
[Re: Jim_]
Biggerfoot
I invented modding!
Originally Posted By: Jim_
The G4 are too slow for a lot nowadays. I would get the Intel model, not just for the great speed bump but as you have seen besides software limitations, most is Intel only anymore, internet has it's hiccups now on PPC. G5 can go to Leopard. The late 2006 models were the Core 2 Duo and can run Lion, the first two 2006 Core Duo models are stuck on Snow Leopard.
I ran Tech Tool Pro 6 on both the Intel and G5 iMac. The hard drives were the same size.
It was amazing to note that the G5 took close to twice the time to finish the same entire test (hard drive test taking the longest).
#588687 - 01/22/1305:20 AMRe: Can Older LCD iMacs and TV Handle Temp Changes?
[Re: Jim_]
Biggerfoot
I invented modding!
Well, I guess I should state it will get to 40 degrees if I do not skip an exercise day...then it would get much colder. My barn workshop with the G5 iMac is probably about 30 degrees right now with it being 5 right now. I would say if I skip today, it would be in the high 20s to lower 30s the next day.
I have to say, I am enjoying having an up-to-date iMac and all of the network benefits. I have the Intel one using Time Machine via my network and I can even use the iSight camera via Remote Desktop to make sure I turned the lights out or whatever.
You seem so talented with stuff, etc., any chance you could do some do it yourself things that capture heat/electricity from the sun to keep the buildings from getting to sub zero temps? I mean, not to get the buildings to 68 degs but to take the chill off?
#588729 - 01/22/1306:29 PMRe: Can Older LCD iMacs and TV Handle Temp Changes?
[Re: KateSorensen]
Biggerfoot
I invented modding!
Both my fitness room and work shop are in larger, uninsulated outbuildings. I do have windows with storm windows in the rooms but that is about it. I am all electric where I am which is fine but it limits me to my heat sources unless I want to spend lots if money.
It is not all that bad to get the rooms up to 50 degrees. I have both the heaters on remotes so I can turn on the heat an hour or so before it is needed from my house. 50 degrees seems to be comfortable to either exercise or work. Today, with it being under 10 degrees, it took only about an hour to have it over 50 degrees and then I was able to turn the heat off.
I have nine zones of heat in my house that are controlled separately. It is pretty nice this time of year as I only heat the areas I need in the morning and evenings. Not too bad for an old farm house!
