Audio Kext for Live Surround Sound Encoding #586847 12/15/12 06:31 AM
P
Paradox4242 Offline OP
P
I unfortunately am not talented in the programming field and I just recently bought a MBP. I want to be able play games using Bootcamp for Windows and be able to have 5.1 channel surround sound. The issue is that the stock drivers for OS X 10.8.x do not support encoding. They do support decoding which isn't my problem. I am wondering if anyone knows of a trustworthy website where I can get a sound kext that allows 5.1 channel surround sound live encoding.
Re: Audio Kext for Live Surround Sound Encoding [Re: Paradox4242] #589381 01/30/13 12:54 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
The only thing I can think of is uninstalling all Realtek drivers and software, restarting the computer and letting Windows install it's own sound drivers.
Re: Audio Kext for Live Surround Sound Encoding [Re: NucleusG4] #590844 02/28/13 01:31 PM
A
avisjacob Offline
A
Is it really possible that it will definitely work after uninstalling and then installing all the drivers ?
Re: Audio Kext for Live Surround Sound Encoding [Re: avisjacob] #590847 02/28/13 05:24 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Don't know.. it's what I read at Apple discussion forums.
