Not to worry #585530 11/13/12 08:16 PM
KateSorensen Offline OP
77 and counting
77 and counting
No biggie. It hasn't happened to me in a very long time, but just now I had my main forum menu go berserk with large numbers of unread posts to read in every forum.
Logging out and logging in made it revert back to the actual number of posts I have not yet read today.
Re: Not to worry [Re: KateSorensen] #585556 11/14/12 01:18 AM
Reboot Offline
I can recreate the same issue probably 100% of the time by starting a Reply to a post, going away from the Reply's tab/window in my browser for a while, then coming back and finishing the reply. I don't know for sure what the time frame is for how long the Reply window must be open to create the issue, seems something like maybe 30 minutes or so.
It's always done that BTW. I believe I checked it with both Safari and Firefox. It's probably a cookie issue. Like you said no big deal though.
Re: Not to worry [Re: Reboot] #585672 11/15/12 10:02 PM
lanovami Offline
This space for rent
This space for rent
Kewl. I might have to try that. smile
We are what we repeatedly do - Aristotle
Re: Not to worry [Re: Reboot] #585770 11/16/12 08:57 PM
M
Mike Offline
Mr Zig
Mr Zig
M
What's the time limit for deleting a post?
Re: Not to worry [Re: Mike] #585775 11/16/12 10:50 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Apparently, 5 seconds before you realize you need to change it! eek
Re: Not to worry [Re: Mike] #585776 11/16/12 11:32 PM
Reboot Offline
I don't know if you can delete the whole post but there is some kind of time limit on editing. If you double post or want it moved or something PM me, I can take care of it, no time limit for me on editing, deleting or moving.
Although if you just decide you shouldn't have said something, think twice next time. grin
Re: Not to worry [Re: Reboot] #585972 11/21/12 04:20 PM
MacGizmo Offline
What?
What?
You should be able to edit/delete a post for any amount of time, unless someone responds to it... then it's set in stone unless Jim fiddles with it.
The Graphic Mac - Tips, reviews & more on all things OSX & graphic design.
