Gaaaaaaaaaah! Now you point out that two cables are different color and thus a pair!! Now you tell me. I originally had black cable red in the audio out.
They work the way they are in the picture. I just checked.
As muh father use to say, "Crap-a-mighty! If it was a bear it woulda bit ya!"
Thanks. My Plextor does about 2.7G at best quality.
I just remembered, if your EyeTV software is about the same as mine, if you go to Preferences/Devices you can choose the quality you want to record, and it tells how big it will be. Mine has this.
Well now, that was interesting. Started to do what you asked for and notice that the picture went away and it said 480 [?] and picture came back for best, better, good. So I knew there was a way to make my picture 1080i but since I guess I am not finicky, I just never bother. I Changed my TV to 1080 and the picture on my puter got even better!!
