With my internal sound on my Mini. I reset the PRAM today to see if that helps and it did. PRAM battery maybe? Nothing else seems to be affected. I'll see if it "sticks" for now.
(I still could use that 250GB internal drive I want, so maybe I can swap the battery out at the same time).
Turn off the wireless, so the Date and Time don't auto set, or set D&T to not automatically update.
Shut the computer down and unplug the power supply from the computer for a bit. Maybe at least 10 minutes or so? Overnight would be a for sure bet. When you reboot it if the clock held time the battery is okay.
#584897 - 11/06/1205:48 AMRe: Still having issues
[Re: Jim_]
I'll try that tonight, then.
When I woke the computer this AM, no internal sound again. There is power to the headphone jack, Sound Pref Pane shows it as active, but there is no sound output. At least, the USB dongle works just fine.
