My computer is still trying to sync with MobileMe (actually, it just started doing that the last couple of days), and it's keeping the computer from sleeping. I'm also noticing that the googleupdater.daemon is running a lot, but I cannot find a way to stop it from auto-updating (I only have Google Chrome and Google Earth installed).
Question is: Can I safely remove the MobileMe.prefPane and the Mac.prefPane from System/Library/PreferencePanes?
Also, is there a way to tell Google apps not to auto-update always?
MobileMe doesn't even exist anymore. It just keeps trying to sync and then timing out. I've been on iCloud nearly from day one. Can I dump those prefPanes?
Dumped the .plist files as stated. I'll go ahead and dump those prefPanes too.
I don't mind Google running its update check daily but, today, it was at it for 6 hours straight (roughly 10AM - 4PM). I may just turn it off entirely, if that is going to be the case in the future.
