Version 10.6: "Snow Leopard" Version 10.7: "Lion" Version 10.8: "Mountain Lion"
My iMac
Processor 3.06 GHz Intel Core 2 Duo Memory 4 GB 800 MHz DDR2 SDRAM Running OS X 10.6.8 [ Snow Leopard ]
So as I recall, there are things to do before I upgrade to "Lion" and then "Mountain Lion"
I remember use guyz going thru that and the discussions. But I wonder if there is a place on the internet where I can get all the info, like, beginning with: checking my Mac for what stuff will not run under Lion? Then, what to back up. Then how to go about buying, downloading, and saving a copy of the Lion? And, all the other stuff.
Egads! Just the thought of all this is going to make me break out with the hives or something. I wish we had our old MacUser club here in McMinnville.
"Will I need to be running Lion to upgrade to Mountain Lion, or can I upgrade straight from Snow Leopard?
According to the information Apple has provided with the developer preview, you need to be running at least the latest version of Snow Leopard (OS X 10.6.8) to install Mountain Lion."
So, Doesn't look like you need to go through updating to Lion at all =)
I think that article also has answers to some of your other queries ...
Kate.. go to System Profiler and look under software.. it will take a minute to see all your apps and there is a column that tells you Intel/ Universal / PPC.
Originally Posted By: Jim_
What NG4 said, any app listed as PowerPC or Classic will not work.
