Ok this is my first hackintosh I need to spend the least amount of money possible. This rig will be Used for Video editing and web browsing and just getting the hang of using osx. This will be my first time Using OSX. I tried picking out parts that will work out of the box because i really dont know how to do it. So if any of the parts could be cheaper PLEASE TELL ME
SDD http://www.newegg.co...N82E16820226151 this is really only for the editing so all the editing programs will be installed on it and the editing will be done on it then transferred to my main WD Green 1tb i dont no if the OSX will be installed on it because i dont know if i am gonna buy it with the rest of the parts
Motherboard http://www.geeks.com...RO-PB-R&cat=MBB this motherboard is limited stock so i am begging you if you see this and need it please dont buy it.
i have a oem 350 watt that is enough and i dont need a case
I would like this system to run OSX 10.8 but if not 10.7 please replay And thanks Also if theres cheaper tell me please
