I can't log in to my macbook pro with my password. I changed my password a few weeks back, and it has been working fine until yesterday. I tried logging in with the old password, and I still can't log in
Thanks for the reply. Would I be able to retrieve all my documents automatically? Am currently on Lion OS, but my recovery disk is Leopard, would still have Lion on it once I recover?
Thanks guys for all the help. I tried rebooting using my install disc and holding down the C button, unfortunately it keeps taking me back to the log in page, where I still can't log in with my password.
Did you try the Command-R tip in the link I posted to boot from the recovery partition? You can also try using the Option key which will bring up a startup disk screen.
What kind of keyboard? If it's wireless or third party do you have an older Apple wired USB one to try instead? I have seen problems even with Apple's aluminum wired ones but it's been a while.
I've tried the Command+R option and pressing the option key while rebooting, but there is still no change. It keeps showing me the log in page, and my password still won't go.
#571027 - 02/15/1202:24 PMRe: log in problems
[Re: Jim_]
Boot while holding the mouse button down to see if that will eject the CD/DVD.
Had that happen once on my wife's Mini. I had to go dig out a damaged clear tray keyboard in order to use the eject key, since the aluminum keyboard's eject key wouldn't do it for some reason.
