How to grab a irregular region on Mac? I need it for my presentation. Is there a good grabbing software available? It doesn't matter it is a shareware or software. Oh, please don't forget download url. I need it urgently, Thanks a lot.
First ,Give you some Shortcuts Keys for capture screenshot on Mac
Command-Shift-3: Take a screenshot of the screen, and save it as a file on the desktop Command-Shift-4, then select an area: Take a screenshot of an area and save it as a file on the desktop
And you just can try spam, which can capture frame region, freehand region, one or all windows and full screen on Mac . Hope it will be helpful to your presentation .
Edited by Reboot (11/13/1106:56 PM) Edit Reason: Bye bye
