Anyone tried NUDC/Servers on Lion or Lion Server? #563089 08/15/11 12:38 AM
A
ashore Offline OP
A
For security reasons, my work network isn't connected to the internet; so migrating to Google, iCloud or .mac aren't solutions.
I've tried Bento (sharing is very limited, no real way to keyword to the address book record), Daylite (way too many users with problems once it is beyond the trial stage), BusyCal (won't sync to PDA w/o MobileMe, which is going to iCloud), several others and still nothing comes close.
Due to evolving security issues, even within a secure environment, we now have to go to full disk encryption. For Mac, easiest is to just go to Lion.
Has anyone tried NUDC and/or the servers on Lion or Lion Server?
Thanks in advance,
Alex
Re: Anyone tried NUDC/Servers on Lion or Lion Server? [Re: ashore] #563538 08/24/11 03:48 PM
E
earplug Offline
E
Updated my MacBook to Lion - Now Contact works fine
Updated my IMac to Lion - Now Contact fails with message " Can't open - PowerPC programs are not supported"
Completely uninstalled, re-installed - NO luck???????
Re: Anyone tried NUDC/Servers on Lion or Lion Server? [Re: earplug] #564249 09/05/11 12:17 PM
J
John Rougeux Offline
Member # -1
Member # -1
J
Since John Wallace doesn't come in here anymore, I will attempt to help you.
Apparently the software code was written for PPC, not intel chips. So what that means is that you HAVE to use 10.6 snow leopard or older versions of OSX.
And forget about it ever being re-written for Lion. Not going to happen.
If you all have to go to Lion, then you must look for alternate software. Good luck
