carp
Dino's are Babe magnets
Loc: Hawaii
Okay I am doing field inspections for this high rise developer. They bought 4 iPad 2s for us to use to log field reports. We then use drop box via wifi , the reports to a central location.
They use (QuickOffice Pro - HD) - The report templates are custom made XML sheets by a hot babe who majored in IT.
Anyway the problem is not major , just a little annoying. When typing and you hit space bar the keyboard reverts to number board , you then have to bring back the letter board for the next word , then space and the number board comes back . Some times you can type in 4 words before this happens in the same cell.
Plus this does not always happen but its about 50% of the time.
The question is ? QuickOffice - quirk iPad - quirk Hot Babe - quirk
