In my search for a new isight stand I came across what I felt was a very unique idea. It is cheap and easy. Just wish that it was eye-level. It isn't exactly what I was looking for but hey, it may be for you!
That is the worst idea ever! The iSight is $130 and its stuck on a .03 CD??!! One of the reasons its a bad idea is that I use mine on the stand and it doesn't ever fall over. I just leave the sticky tape on the bottom and it sits on top of my desk. Why stick it to a cd???
if you can't afford a sight flex, go to walmart and spend 9 bucks on a mini tripod and work something like this
Wow, a CD for an iSight stand. I would have never thought about doing that...for obvious reasons. Well, I'm with krusher here and would get a mini tripod for that. But the flex is just plain sexy. If I used a webcam, I'd get that. Good find krusher. I'm pretty sure someone here will find an alternative use for that.
thats the worst tripod mod I have ever seen, and in fact I saw that on google when you do a search for isight stand. Its ugly, ugly and ugly. O yea, did I mention that its ugly. Granted that the cd isn't the best alternative its basically free, and looks better than the tripod. I agree though, I just have mine, atm, sitting on the original stand, it looks better than a cd, but hey, it was a good idea. I do like the sighflex and I think that I might go that route, just not so sure about the 30 bucks for it.....hmmm.....I am trying to think of alternatives.....maybe duck tape! :P
1st time I've heard of an iSight stand. Thanks for making this post so I can decide if this is something I would like to carry in one of my online stores.
I have had manufactured a threaded steel disk that enables you to mount your iSight to a threaded tripod sled. You can affix the Apple plastic mount to the disk and the disk to the sled; or you can use the disk alone and attach the iSight magnetic base.
I have them for sale at eBay item 160404303393, with several photos of various configurations. Its brutally simple design affords many applications. And for those who care, I could have had them made in China for cheaper, but used a small Midwest machine shop instead.
#516859 - 05/04/1003:41 AMRe: iSight Stand
[Re: tlmurray]
Antonio NArF!
Loc: San Francisco, CA
No too shabby... Think you can add a bending arm to that? I'm thinking maybe a double-elbow setup for fine-tuned flexibility, and rotation would be good, too.
yeah, i have 2 iSight cameras and only 1 computer left that needs 1. but i have 2 Dell displays attached to it and i tape my iSight to the top and back of a display, but it inevitably falls off after a few weeks. i considered the Sight Flex, but it doesn't seem very stable. i'll have to read up on timmurray's Ebay solution. thanks.
