• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mac » Hardware » What external Burner works with iDVD?
Page 2 of 3 < 1 2 3 >
Topic Options
Hop to:
#561923 - 07/26/11 07:36 PM Re: What external Burner works with iDVD? [Re: NucleusG4]
iMacsoontobe Offline
Where's the RAM?
Loc: The Burgh
Thanks to everyone!! smile
Top
#561924 - 07/26/11 07:48 PM Re: What external Burner works with iDVD? [Re: iMacsoontobe]
NucleusG4 Offline
Master•Blaster
Loc: Miami, Fl.
Originally Posted By: iMacsoontobe
For the 2 or 3 times a year I need to burn a cd or dvd, it seems senseless to spend over 200 for an internal superdrive.
I thought I had read that iDVD doesn't play well with some external burners.
TIA
Joe
Why not find a compatible internal? Is this a laptop?
http://davidbearphotography.com/
Top
#561947 - 07/26/11 11:03 PM Re: What external Burner works with iDVD? [Re: NucleusG4]
Where's the RAM?
Loc: The Burgh
iMac 20inch
Top
#561951 - 07/26/11 11:43 PM Re: What external Burner works with iDVD? [Re: MacBozo]
Reboot Online   content
Loc: Columbus OH
Originally Posted By: MacBozo
Originally Posted By: Reboot
This should work. Really have to go now. Bye. smile
http://www.amazon.com/Samsung-External-Optical-SE-S084D-TSBS/dp/B0044DEDBG
Faster compatible one here too (also a Samsung mechanism):
OWC
That one has a power supply to plug in though, it's not bus powered. I like the bus powered for keeping things tidy I guess, and ease of storage if one doesn't use it regularly.
The speed thing is over rated IMO. I burn a lot of DVDs, 100s over the years, and even more CDs. Being able to burn that fast, and getting a successful burn are two different matters though. My 2 Pioneer internals go to 16x but I never burn past 4x or 8x for reliability. I've found that burning at max gives too many coasters on the 4 different pioneer drives I've burned through over the years. I use good name brand blanks too.
I guess if one was doing production burning all day or something it would be worth going 16x and getting a few coasters to save the 5 minutes longer it takes to burn 8x.
The Matshˇta in my iMac can never burn any disc max, I have always had to choose 4x. It doesn't have much use on it either, it's always been that way. The elderly couple I got the machine from didn't even own any blanks. I usually just take it to the old G4 with the reliable Pioneer drives.
Well iMacsoontobe, you should have enough ammo to make a decision as to what suits your needs. smile
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#561952 - 07/26/11 11:47 PM Re: What external Burner works with iDVD? [Re: NucleusG4]
Loc: Columbus OH
For the few times a year he says he would use it I wouldn't recommend replacing the internal anyway. He doesn't want to take the iMac apart if remember right so it would be well over $200 to take it in to have it done. I would charge $120 plus the drive which is around the standard labor charge to do that job.
Edited by Reboot (07/26/11 11:50 PM)
Edit Reason: Took out the stuttering. :-D
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#561955 - 07/27/11 12:05 AM Re: What external Burner works with iDVD? [Re: Reboot]
NucleusG4 Offline
Master•Blaster
Loc: Miami, Fl.
Yah.. I got it. I didn't know it was an iMac...
On another note.. I get http://en.wikipedia.org/wiki/Taiyo_Yuden
and they work great and are pretty inexpensive.
I go ..... here
Top
#561967 - 07/27/11 01:34 AM Re: What external Burner works with iDVD? [Re: Reboot]
Where's the RAM?
Loc: The Burgh
OWC
Thanks much Reboot!!
I do have plenty of info now.
The one on Amazon does have some negative reviews, but I guess you'll have that. Not sure why the Apple one for Macbook Air and Mini's isn't compatible, cause I would probably buy that knowing Apple would back it up. For the the first four years of owning my first iMac, I bought only Apple branded DVD's, they were like$2.50 each I think. I may go the Bestbuy route, only for the easy return factor if it doesn't fly. One of the "negatives" with the self powered seems to be needing 2 USB ports instead of one? That was according to the reviews on Amazon.
Edited by iMacsoontobe (07/27/11 01:35 AM)
Top
#561969 - 07/27/11 02:13 AM Re: What external Burner works with iDVD? [Re: iMacsoontobe]
Loc: Columbus OH
I see, it's the two power plug kind. From the reviews it seems that the Macs, even the MacBook Air can run with just one cable plugged in though. I have portable external HDs with the dual cable. They work fine on my Macs with one cable. Usually it's Windows laptops that need the extra power from the second port connection. If you're not going to be using it that much and can get by with taking up two ports if needed for the times that you have it plugged in, the price is great. I doubt you'll need two though with that iMac.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#583577 - 10/16/12 05:17 PM Re: What external Burner works with iDVD? [Re: Reboot]
Where's the RAM?
Loc: The Burgh
Can I also use an external DVD burner to .......Plug old sony handycam into TV and while playing on TV burn a DVD of what is playing form Sony handycam into TV?
Top
#583585 - 10/16/12 07:29 PM Re: What external Burner works with iDVD? [Re: iMacsoontobe]
Loc: Columbus OH
I doubt that. You'd have to connect the Sony to the computer probably. You need some kind of media interface on the computer to capture the analog input from the camera.
Or did you mean connect the DVD burner directly to the TV also, in which case I haven't a clue on that one, probably not though. I can't keep up with all this stuff myself. grin I doubt the TV would do a USB interface with the DVD player much less have burning capabilities.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.046 seconds in which 0.029 seconds were spent on a total of 14 queries. Zlib compression enabled.
