There are some hints in this forum, but I have never used Now X so I can't say. The Now X forums were migrated here a little over 2 years ago.
I would suggest using the Advanced search here, set it to newer than 3 years or so. Also click on the Now Software Support forum choice on the left of the Advanced search window before searching.
Finally ready to migrate out of NUTD & Now Contact for OSX Lion. Bento, Daylite, SOHO Organizer???
Any suggestions on the easiest integration?
I would be interested in knowing what you move to. I have looked at Bento (no letter merge or printing), I looked at Daylite (way too cumbersome, it does too may things and not enough very well), soho (see daylite comments).
I have been forced to keep a old mac running just to keep going with up to date.
I wonder how, if all these other software companies keep going juts how to NOW manage to crash and burn?
All I want is a contact manager that i can import a photo of the person (decent sized), call up their information, create contact lists and do some sort of simple letter merge with the info.
