Are you having trouble launching anything else? The Terminal was a permissions problem too. Poke around and try a bunch of apps and utilities too to see if they launch.
I'm still leaning towards rebuilding everything from TM again, but running the vsdbutil Terminal command while booted from the DVD to change the TM drive to ignore ownership so that maybe TM can read all of the files and you can get a complete backup.
Did you get the DVD working? We would need to do that to rebuild again.
#557032 - 04/29/1106:04 PMRe: Been a long time, HELP!!!
[Re: NucleusG4]
iMacsoontobe
Where's the RAM?
Loc: The Burgh
LOL actually got some of my pics back, problem is can only go back to 4/22/11!! Won't let me go back any further currently....at some point pics I'm still missing were there, but now gone.
I didn't actually follow those exact instructions, wasn't able to to "edit" the "shells~orig copy" in the etc folder, so I copied it on to the desktop and edited there, and then dragged it back into etc folder....yikes!!! Now I'm not even sure Terminal is giving me the proper response with Reboots sudo command.....but I'm putting a hold on that currently...
Next problem is TM hd is 500 GB but it is saying it only has 70 gb available!!! the iMac is a 320 gb that has 152 gb available. Now I know TM is making multiple copies that take up more room, but since it only lets me go back to 4/22/11 something is out of whack!! Think there must be corruption somewhere, but should i format the 500gb TM drive and then to a fresh backup of my current iMac? Or has my imac been corrupted in the restore process?
No!! You don't want to do that since the current install isn't working right. See my previous post, we should rebuild again sans ownership on the TM drive.
#557039 - 04/29/1106:28 PMRe: Been a long time, HELP!!!
[Re: Jim_]
iMacsoontobe
Where's the RAM?
Loc: The Burgh
Originally Posted By: Reboot
I don't know why your permissions are so fubar. Did you ever add or delete any users?
If Michael's suggestion doesn't work we'll need to set the drive to ignore ownership. In Leopard and lower there was a checkbox in the Get Info, but Snow Leopeard is protecting us from ourselves.
Launch Terminal, then type the following below ([space] = a space)
sudo[space]vsdbutil[space]-d[space]
then drop your TM hard drive on the Terminal window, it should then read "sudo vsdbutil -d /Volumes/Name of your HD," then hit Return. It will ask for a password.
To set it back change the -d to a -a. Running TM should change it back too.
Once you get everything rebuilt, sometime down the road I'd wipe the TM drive and start over, there is some kind of corruption, possibly due to your HD failing.
#557040 - 04/29/1106:35 PMRe: Been a long time, HELP!!!
[Re: iMacsoontobe]
iMacsoontobe
Where's the RAM?
Loc: The Burgh
Sooo are we iChattin tonight? If we are just pop up on iChat, handing the web over to my daughter for a while, but i told her if you pop up on ichat to tell me...
