• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mac » Software » Been a long time, HELP!!!
Page 1 of 8 1 2 3 4 5 6 7 8 >
Topic Options
Hop to:
#556602 - 04/25/11 01:17 PM Been a long time, HELP!!!
iMacsoontobe Offline
Where's the RAM?
Loc: The Burgh
Hi everyone,
Hopefully some people still remember me....
Well my 2007 iMac running is 10.6.7 is driving me crazy!!!
A few weeks ago it started "beachballin" but after a few shut downs everything seemed normal, note I was only running Safari and Mail. 300 GB HD only using about half of that. Well it started again Saturday nite and I have been unable to get my desktop back after many shut downs, fsck's, repair disk utility,..ect I was going to do a reinstall, but it starts to go through and then about 10 minutes into it, says not enough space!! There is 150 GB of free space!! I have not tried to restore from Time Machine yet. Please help and old forum member....
Joe
Top
#556607 - 04/25/11 03:17 PM Re: Been a long time, HELP!!! [Re: iMacsoontobe]
Where's the RAM?
Loc: The Burgh
set up a Genius Bar appointment....but would still love some input from all the wisdom, I know resides on here!! smile
Top
#556610 - 04/25/11 05:02 PM Re: Been a long time, HELP!!! [Re: iMacsoontobe]
Reboot Offline
Loc: Columbus OH
Does fsck say all is well?
Sounds like you may need Disk Warrior, it seems you may have some disk corruption that Disk Utility can't fix.
Another fix would be to reformat the drive to clean up the corruption then restore from Time Machine. Takes much longer but it is much cheaper than having to buy Disk Warrior.
Could even be bad RAM, or a hard drive that is physically failing.
Good luck with the "Geniuses." smirk
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#556611 - 04/25/11 05:09 PM Re: Been a long time, HELP!!! [Re: Reboot]
Where's the RAM?
Loc: The Burgh
Reboot!!
I knew there were "good people" on here!
fsck fixed a few things and did say all was well
I thought about doing the disk format and reinstalling from scratch, but wanted to keep "looking" first.
did use the original Leopard install disk and ran Apple Hardware Test, not sure how extensive that is, but it said all was well...
I take it you're not to fond of the geniuses in the Apple stores?
so if unless I get no where with the genius, I should reformat with disk utility and do a clean install?
Also, if I bought a new imac, I assume I could just use Time Machine to basically make it my "old" imac? Thinking I would lose applications like Office?
Top
#556612 - 04/25/11 05:35 PM Re: Been a long time, HELP!!! [Re: iMacsoontobe]
Reboot Offline
Loc: Columbus OH
Glad to help. smile
The Geniuses tend to just nuke and rebuild from scratch in order to "fix" things. In the case of disk corruption or a system part being broken it does work, they are just doing assembly line type repair. Nothing fancy and nothing non-Apple.
The Genius bar does come in handy for me to determine if it is a power supply on a mini, or the power supply or charging circuit on laptops since I don't have every power supply. They are the most knowledgeable in the store but how knowledgeable? YMMV.
For your problem if you boot from the install disk and on the second screen go to Utilities/DiskUtility you can erase the disk, then for the next step, under Utilities, you can run Restore System from Backup to rebuild from Time Machine.
If you get a new machine, when you first start it up it gives you a choice to rebuild from Time Machine or a backup. You won't lose any apps. It does a great job. There may be an app or two, QuickBooks is one that comes to mind, that will require a new serialization as they are machine specific. Office should be fine.
So the name will soon be NewiMacsoontobe? grin
Edit - It will take probably 4-5 hours to rebuild 150G of data BTW.
Edited by Reboot (04/25/11 05:37 PM)
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#556614 - 04/25/11 06:23 PM Re: Been a long time, HELP!!! [Re: Reboot]
Where's the RAM?
Loc: The Burgh
Thanks!!
I'm wondering now if it is worth the trip or if I should just to a reformat and clean install.
Probably go, just in case it is something else.
And yes, I'm due for a NEW iMacsoontobe!! That is why the name remains!! LOL
Hope all is well with you.
How was your Easter?
Top
#556618 - 04/25/11 07:13 PM Re: Been a long time, HELP!!! [Re: iMacsoontobe]
MacBozo Offline
I think Reboot has it pretty much defined. I had the "disk is nearly full" warning once on my trusty G4 when I knew that it wasn't. It was some kind of extents overlap error (DW couldn't fix it, so I had to run TechTool Pro and then DW to straighten it out).
Good luck getting it sorted out.
Top
#556621 - 04/25/11 07:37 PM Re: Been a long time, HELP!!! [Re: iMacsoontobe]
Reboot Offline
Loc: Columbus OH
Letting it just rebuild from TM would be less configuration and quicker than a reinstall then migration. You don't even need to install, it will just rebuild from your last backup point.
Although a clean install is a fresh start. You can do a clean install then run Migration Assistant when it starts back up to get a fresh system yet still retain your apps and settings. Make sure after running Migration Assistant that you run all software updates before trying to run any apps.
Make sure you erase the drive first before doing anything, to get rid of the disk corruption. You probably should Partition the whole drive again. Choose 1 Partition, then choose GUID under Options in the Partition tab.
Disconnect the TM drive after it rebuilds the system. After you're 100% positive that it's up and running again you'll probably want to erase the TM drive before letting it backup again as it will probably want to backup everything again anyway since it will see a new install.
Easter was a hoppy time, thx. smile
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#556639 - 04/25/11 11:35 PM Re: Been a long time, HELP!!! [Re: Reboot]
Where's the RAM?
Loc: The Burgh
Michael!!!
Good to hear from you on here! Hope all is well in the sunshine state.
Reboot, went to the Genius Bar, it looks like a bad HD. :((
They wanted $220 and 5 to 7 days!!! frown
There is an independent Mac Retailer in this neck of the woods, called them and it will be somewhat cheaper and should be able to get it done in a day.
Top
#556674 - 04/26/11 01:47 PM Re: Been a long time, HELP!!! [Re: iMacsoontobe]
Reboot Offline
Loc: Columbus OH
Since you have a backup I'd try reformatting first, I don't trust their talents.
If you launch Disk Utility, click on the drive on the upper left of the DU Window, what does SMART status on the bottom right say?
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.046 seconds in which 0.029 seconds were spent on a total of 14 queries. Zlib compression enabled.
