1.Sexual intercourse, also known as copulation or coitus, commonly refers to the act in which the male reproductive organ enters the female reproductive tract. 2.The two entities may be of opposite sexes, or they may be hermaphroditic, as is the case with snails. The definition may additionally include penetrative sexual acts between same-sex pairings, such as penetration of non-sexual organs (oral intercourse, anal intercourse) or by non-sexual organs (fingering, tonguing), which are also commonly practiced by heterosexual couples.
#551304 - 02/12/1110:34 AMRe: Old link results...
[Re: Leslie]
keymaker
I invented modding!
No I think in you're getting a bit bogged down in anti-Clintonesque type sophistry there blurring the distinction between sexual intercourse and sexual relations.
Unfortunately it is not just me you must take on with this one. Here is another definition of sexual intercourse from Merriam Webster.
1 : heterosexual intercourse involving penetration of the vagina by the penis : coitus 2 : intercourse (as anal or oral intercourse) that does not involve penetration of the vagina by the penis
A glow worm's never glum Cause how can you be grumpy When the sun shines out your bum?
We are having a dinner party tonight and it is raining here, as in glum, so I am going to use that at some point before the day is over. I will give you credit.
