Ethernet cable fail #551007 02/09/11 01:28 AM
MacBozo Offline OP
The Cat5e cable that runs from my router to the room that my father-in-law occupies while he is here and connects his G4-400 PowerBook to the 'net seems to have failed. I tried another, too short to run through the attic, cable and that worked, so it's off to find a 40 - 50 foot cable and crawl the attic.
Re: Ethernet cable fail [Re: MacBozo] #551018 02/09/11 05:14 AM
Reboot Offline
Do you have the crimp tool to replace the ends?
Re: Ethernet cable fail [Re: Reboot] #551022 02/09/11 09:00 AM
scottyb Offline
Where's the cache?
Where's the cache?
It seems kind of strange that a cable would just "fail", especially one that stays put like that. Just a WAG, but could your router be failing, and losing it's ability to push a signal through such a long cable?
Re: Ethernet cable fail [Re: scottyb] #551030 02/09/11 12:49 PM
NucleusG4 Offline
Master•Blaster
Master•Blaster
Rats?
I remember running all new phone and ethernet and coaxial through my loooow Florida attic several years back. Ugh.
Re: Ethernet cable fail [Re: Reboot] #551035 02/09/11 02:26 PM
MacBozo Offline OP
No crimp tool on hand. New cable is only $20 at Best Buy.
Re: Ethernet cable fail [Re: scottyb] #551036 02/09/11 02:28 PM
MacBozo Offline OP
Tried a ~20 ft. cable and that worked just fine.
Re: Ethernet cable fail [Re: MacBozo] #551043 02/09/11 05:01 PM
Reboot Offline
Just a thought, if you weren't in a big hurry, you could get;
One of these http://www.outletpc.com/c0279.html
A couple of packs of these http://www.outletpc.com/c0267.html
And one of these http://www.outletpc.com/wj8174.html
For $25 and change shipped, and be set up for the future. Ethernet cables can be such a rip.
Re: Ethernet cable fail [Re: Reboot] #551055 02/09/11 11:09 PM
MacBozo Offline OP
That's why I found one for $20 instead of $50. laugh
Hopefully, the TiPB will die and we can just hook him up to the wireless network in future visits. wink
