Don't hit me with a regular stream of "oh great" or "how's this going" as I don't have the time, but I've just found a clue on this ... it may have something to do with Clark's broken avatar.
I've sent a note to the developer to investigate.
Neil
I removed Clark's broken avatar and things still overlap, so that's not the problem. His avatar was broken because Apple changed their MobileMe scheme BTW.
MicMeister
Le Skibum & Pixelsmith
There's four more html validation errors with the threaded view (59) than there are in the flat view (55) so the culprit may be among them. I'm guessing it's some apostrophe or parentheses or similar bug in the template someplace where the html output is being defined. And all those html validation can't be too good either.
W3C Validator. Copy and paste your page URL in the textbox and hit check.
So you can't use your iDisk/Pictures folder anymore, you must either use your iDisk/Public folder, or make a folder in your iDisk/Sites folder, then move your images to either Public or the folder you made, and link from it. There is no one set url anymore, it all depends on what you name the folder or where you put the images.
MacGizmo
Moderator
Loc: Arizona
I wish I could be of some help, but I've never come across this issue using Safari, Firefox, Chrome, Flock, or any other browser - with or without adblockers turned on.
I suspect that this problem is not with the server or site, but with the individual browser (maybe the encoding settings?). If it were the site code, wouldn't it appear for everyone all the time?
MicMeister
It appears exactly as described on Safari, Firefox and Opera on my Mac and only in threaded view, so it's most likely not a browser issue. And I only have an adblocker on FF, so shouldn't be that either.
OTOH, I've only managed to reproduce the issue with the mentioned thread, others show just fine in the threaded view. Might have something to do with the reply depth, actually and the title not fitting properly in its field anymore:
I'd also look into making the HTML output as valid as possible, as invalid HTML can cause all sorts of funkiness. 55 to 59 validation errors is actually pretty bad. Then again, most probably go away by fixing some syntax error at the beginning part of the template.
It only does it with long threads or if there is a long url in a post.
Look at this thread, make sure it's in threaded view, not flat.
