Boot from an install DVD. That will tell if it's hardware or software.
If the keyboard isn't responding C may not work so you'll need to mouse around to the Startup Disk preferences to set the DVD as the boot device. If the keyboard won't open the tray you'll need to hold the mouse down at startup to open the DVD tray.
#547388 - 12/17/1009:43 AMRe: Keyboard died
[Re: Jim_]
Acumowchek
Blink
Loc: Petaluma, CA
OK, third times a charm. Sort of. As a last ditch effort, I decided to do an Archive and Install. Big mistake because it asks for a password at login. No keyboard, no login. I called Apple help last night, and they've never heard anything like this. I love setting a precedent! This morning I brought home an Apple aluminum keyboard aaaaand: It worked! BUT, the login keeps rejecting my password. Multiple attempts to boot from the DVD failed. It keeps ejecting the DVD at startup, even when holding down the C key. Maybe I should do a PRAM reset? Any suggestions?
Is it the correct DVD for that machine? It seems it may not be. Is it the one that came with the machine? Going to need some details. What machine is it exactly. What kind of install DVD is it. The DVD should have a version number and date on it.
Did you follow my instructions above for booting from the DVD?
You won't need to enter a password to do that, as long as the Startup Disk prefs aren't locked.
One last thought, have you tried another mouse? Maybe it's fubarring the keyboard commands. Set the startup disc like I mentioned above then immediately unplug the keyboard and mouse after you restart.
#547403 - 12/17/1011:17 AMRe: Keyboard died
[Re: Jim_]
Acumowchek
Blink
Loc: Petaluma, CA
PowerMac G5 dual1.8.
I'm using the Leopard install DVD, which worked a couple days ago. I'm sure I still have the original discs that came with the computer, just need to fine it. I'll try that next. Can't choose a startup disc, since the only thing that comes up is user login asking for password. Maybe boot into Safe Mode?
Target disk mode is another good idea. Either put the G5 into TD mode and see if its hard drive can boot another machine and the keyboard can work, or TD another machine and see if it can boot the G5 and have the keyboard work.
