#547182 - 12/15/1001:32 PMRe: Keyboard died
[Re: MacBozo]
Acumowchek
Blink
Loc: Petaluma, CA
OK, home from lunch. Unplugged USB hub (with power supply), connected only keyboard and mouse to back of MacPro, rebooted, and only the mouse works. It's like there is no power going to the keyboard. Not even the Caps Lock light goes on. I trashed several prefs in hopes that would work. It didn't.
#547189 - 12/15/1002:14 PMRe: Keyboard died
[Re: MacBozo]
Acumowchek
Blink
Loc: Petaluma, CA
Sorry about that. Mouse is plugged into back of Cinema Display, not keyboard. The KB is the kind that came with the G5, resting in a clear plastic tray. The other KB was from an old G4 that still works. I should bring my KB to work to see if it's the KB or the Mac. I'm stumped.
SMC RESET • Shut down the computer. • Unplug the computer's power cord and all peripherals. • Press and hold the power button for 5 seconds. • Release the power button. • Attach the computers power cable. • Press the power button to turn on the computer.
#547199 - 12/15/1002:52 PMRe: Keyboard died
[Re: NucleusG4]
Acumowchek
Blink
Loc: Petaluma, CA
Nope, no wireless keyboards.
SMC Reset? You might be on to something. As I was arranging and rearranging wires last night, the KB was working. After several rounds of plugging/unplugging things, it stopped.
This will have to wait until I get home. I can hardly wait to find out!
Edit: Damn. SMC RESET is for Intel only.
I bought a replacement PRAM battery months ago, but never installed it. Could that be part of the problem?
Acumowchek
Blink
Loc: Petaluma, CA
Already tried trashing UniversalAccess.plist. Nada. I have Mouse Keys turned off. I don't have another user (my bad) and can't create one without the KB. I CAN log in using Back to my Mac and try to do it remotely. We're havin' some fun now!
#547215 - 12/15/1004:32 PMRe: Keyboard died
[Re: MacBozo]
trey
Loc: The Wizard's Balcony
Do you have another computer that you could login via a remote desktop session? If you don't have Screen Sharing enabled, you may be out of luck on that one.
Try booting into Open Firmware by holding [command]-[option]-O-F at startup. Can you type at that point? If so, type
reset-nvram [return] reset-all [return]
The computer will reboot at that point, and let us know what happens.
If you CAN'T get into Open Firmware by holding the key combo at boot, try holding down the power button from a powered-down state until it goes into Open Firmware and see if you can enter the above commands.
