When I go to the home screen, from an app or when unlocking from the lock screen, the icons/folders all swoop in from the corners. Slowly. Maybe it happens so fast on your phone that you've never noticed it .
Edited by padmavyuha (12/08/1010:59 AM)
I'm jailbroken with 4.2.1, yes (which is a little snappier than 4.1). Everything works fine and I'm generally resigned to the slowness of 'old' tech with little ram in this context. It's just that after finding an app that immensely speeded up opening my folders by switching off the animation, I'd really like to find a similar way to switch off the home screen animation too, which is completely superfluous to my needs. So far no joy, but I'm asking around with jb devs to see if someone wants to crack this one too.
Multitasking has become patchier to use in 4.2.1 for jailbroken 3G's, at least - but then there's only really room for 3-4 apps running at once anyhow .
Edited by Reboot (12/13/1012:37 AM) Edit Reason: Moved the BS to clean this thread up.
