Now Up To Date and Contact Address Labels #546827 12/11/10 04:19 PM
M
Maris Fravel Offline OP
M
I just discovered Now Software ended in March 2010. I use NUTDC only for the address list and label printing features. For the first time I am trying to print return address labels, Avery 5267. This Avery label number (80 1/2" x 1-3/4" labels per sheet) is not in the list on my copy of version 5.3.2, and none of the other non-Avery labels listed are this size. Is it possible to download an improvement that will include Avery 5267, or must I migrate to another program ?
Re: Now Up To Date and Contact Address Labels [Re: Maris Fravel] #547074 12/14/10 09:56 PM
Reboot Offline
In Contact go to Define/Print Templates/Labels. Click the + sign at the top to add your own custom label name.
After naming your label and clicking OK, click "Edit Layout Dimensions." It will take some trial and error but will solve your problem. You can define how many Across, Down, space between, etc. Once you find it it's pretty self explanatory.
