Mike
ZigMeister
Loc: SW Illinois
I'm looking for a good monitor for a Mac Mini. So far, I've had recommendations for Samsung monitors because they all seem to have DVI input/ports. Any recommendation for other brands?
#545654 - 11/28/1010:19 AMRe: Monitor for Mac Mini?
[Re: Mike]
Any modern monitor is going to have DVI input. As long as your model of Mini can support it, you can get the largest monitor that it will support. The new Minis have HDMI out (they include the HDMI-DVI adapter) and a Mini Display port, and they support a much higher resolution than previous models. Samsung monitors are very good. I still like my Viewsonic 19" wide monitors that I'm currently using for both the Minis here. My wife's 1.66 GHz Mini has no trouble driving our 32" HDTV at its native resolution (1920x1080) via a DVI-HDMI cable.
#545655 - 11/28/1010:57 AMRe: Monitor for Mac Mini?
[Re: MacBozo]
Mike
ZigMeister
Loc: SW Illinois
Thanks for your advice! Do I need any additional special cables for the hook-up to the monitor, or does Apple include everything for immediate hook-up?
I was taking 5 from raking the last of the $#!*@ leaves, probably oxygen depraved. (carpŠ) I saw where you mentioned that it comes with the adapter when I came in the second time.
