I actually don't have MobileMe, I have no need for it, but I do administer for a few clients that use it so I am familiar with it.
Originally Posted By: KateSorensen
ImageWell, after sending your image to iDisk, puts the url on the clipboard so you can paste it into a post here.
Okay, that cleared something up. I've never used that feature I guess. I just manually upload to my web space my ISP gives me or my website.
Obviously the information ImageWell is sending to the clipboard is now wrong, that may be where our miscommunication has been. I didn't know you used that feature.
So use ImageWell to upload using the Folder function, but make sure the structure of the url is like I posted above.
#545454 - 11/25/1012:22 PMRe: Free Mobile Me coming?
[Re: MacBozo]
carp
Dino's are Babe magnets
Loc: Hawaii
Originally Posted By: MacBozo
In ImageWell Prefs, select Folder. That brings up this window:
Click on the Button that has the ... on it to navigate to your Pictures folder on your iDisk (assuming you created a new Pictures folder in Web > Sites and copied/moved your pictures/files there). Then, use http://web.me.com/yourusername/Pictures/filename for the file/pic that you want to post. It still results in a slow transfer/save from IW. I'm going to try some different settings in IW and see if that can be sped up.
Ohh you know what - I don't have that folder option , in Locations. All I have is iDisk - FTP or WebDave ? What version of Image Well you have maybe thats it.
