Actually, Transmit (or another FTP client) does it much faster than the Finder or, in this case, IW. I think I'll simply save an IW pic locally and then use Transmit to do the transfer to my iDisk.
Yes Transmit! That situation will speed up your process.
When hagen posted that I set to work on the fix took a few hours of my time - then read your post much later and tried that and that did not work either.
We may have to send Reboot a pineapple and macadamia nuts from Hawaii and some wine from Oregon or he will get miffed at us
Yes he did. So I tried it and I posted my results a few posts below that. "Not Supported."
Sigh sigh?
Well smarty pants
Tried what? Hagen said try WebDav, and I reported back that it didn't work, I didn't suggest anything in that post.
Besides, any solution that I posted after reporting back works. I tried them myself first. If they don't work for you you're not comprehending what I wrote and doing something wrong.
1. Put a picture in ImageWell 2. Manipulate it. 3. Send same picture to iDisk using ImageWell 4. Post resulting url from ImageWell into a MacTech forum response?
I'm not going to ask you how you did it nor do I want you to direct me to a thread explaining procedure, I just want to know if answers to questions above are all "yes". Thanks
*Using your "Folder" method will not let you send a new photo jpg to iDisk. Right?
When hagen posted that I set to work on the fix took a few hours of my time.
To me, Hagen is saying that it appears ImageWell is not going to work like it use to for .mac. So he will not be updating/revising ImageWell as he knows of no available fix.
Svend: Don't know. ImageWell connects to idisk.mac.com with WebDAV and that's how it sends the file up to the iDisk. If WebDAV doesn't work with mobile me (idisk.me.com) then ImageWell can't upload the file. If WebDAV works with mobile me then it's just a matter of inputing the server, folder, URL fields correctly for it to work just like the .mac accounts did.
There is no 3rd party SDK for mobile me from Apple. Apple provided a 3rd party SDK with the .mac services but not with mobile me. So it would seem that Apple does not want 3rd party developers to interact with mobile me. Slowly services are being discontinued with the .mac accounts.
Unless Apple starts to document or provide 3rd party SDKs for uploading to mobile me I think the writing is on the wall here - mobile me is not intended for uploading images and linking them in discussion boards.
I'll check for more information, but most likely any update to ImageWell will be to remove the iDisk option. ImageWell is going to be in the Mac App store and they have strict rules about using undocumented stuff and I'm sure using mobile me in an unapproved manner will get the App rejected.
1-3 yes. Clarify what you mean in #4 though by "resulting url." Do you mean using the url format http://web.me.com/username/foldername/picname? Where foldername is the folder you made in iDisk/Web/Sites. Yes to that if so.
#545409 - 11/24/1004:54 PMRe: Free Mobile Me coming?
[Re: KateSorensen]
Originally Posted By: KateSorensen
Are you saying you can:
I can do all those things. Not a big deal with the Public folder.
