f anyone wants to try uploading with ImageWell to idisk/mobile me, then I would suggest that you try using the WebDAV setting instead of the iDisk setting in the drop down list.
iDisk uses WebDAV to upload. When you change ImageWell from iDisk to WebDAV you can type anything you want for the URL to paste after uploading. Also you can change the server from idisk.mac.com to idisk.me.com and the folder.
Hopefully this makes sense.
I don't have a .mac account to test this out.
Cheers all. _________________________ Yo soy un hombre sincero de los alpes suecos. Con los pobres de la tierra, quiero yo mi suerte echar.
Edited by KateSorensen (11/23/1010:01 PM) Edit Reason: Linky
#545337 - 11/24/1006:39 AMRe: Free Mobile Me coming?
[Re: Jim_]
Actually, Transmit (or another FTP client) does it much faster than the Finder or, in this case, IW. I think I'll simply save an IW pic locally and then use Transmit to do the transfer to my iDisk.
Yes he did. So I tried it and I posted my results a few posts below that. "Not Supported."
Sigh sigh?
Well smarty pants
When hagen posted that I set to work on the fix took a few hours of my time - then read your post much later and tried that and that did not work either.
