I moved my pics from the Pictures to the Public folder. The url is as follows:
Why did you do that ? ?
Because that's what works. You can't post pics from the top level Pictures folder anymore.
BTW having all of your pics in the top level Public folder enables anyone to get in read only by just taking the picture name off of the url. A better solution is to use Michael's suggestion about directing ImageWell to the folder you made in Web/Sites using the Folder option in the ImageWell Preferences, that way no one can see everything you have. It was all explained in the 2 links above and Michael's post, re-read it. I can't think of a better way to explain it than what we have done.
#545163 - 11/22/1003:39 PMRe: Free Mobile Me coming?
[Re: Jim_]
I know about the general access business, but don't really care. There's nothing in there to keep secret. If I were in the creative arts racket I'd feel different about it.
#545164 - 11/22/1003:39 PMRe: Free Mobile Me coming?
[Re: Jim_]
carp
Dino's are Babe magnets
Loc: Hawaii
Originally Posted By: Reboot
I guess we're just going over your head again.
I dunno
I follow the suggestions, I believe
1 - Members leave out (information) thinking I should be able to fill in the blanks sorta thingy ? ? I don't know.
Anyway Following what they are saying is just not working. Most of the promblem is Image Well - I believe , keeps porting in extra ///// or .... that kind of stuff.
#545165 - 11/22/1003:40 PMRe: Free Mobile Me coming?
[Re: carp]
In ImageWell Prefs, select Folder. That brings up this window:
Click on the Button that has the ... on it to navigate to your Pictures folder on your iDisk (assuming you created a new Pictures folder in Web > Sites and copied/moved your pictures/files there). Then, use http://web.me.com/yourusername/Pictures/filename for the file/pic that you want to post. It still results in a slow transfer/save from IW. I'm going to try some different settings in IW and see if that can be sped up.
