#545089 - 11/22/1005:11 AMRe: Free Mobile Me coming?
[Re: carp]
Since I keep my iDisk mounted (not a local copy) on my desktop, I selected Folder in ImageWell's Prefs and specified the path to my iDisk > Web > Sites > Pictures and it worked - slow, but worked.
Thanks Michael yeah I did the picture move before, I guess (ImageWell) keeps defaulting back even when using it under webDave.
I'll try again later.
No offense Steve, but take the time to read and try to comprehend both threads that I posted links for, carefully. All of your answers and options on this are there and in the links posted in them. The ImageWell solutions, including the one Michael gave above, were posted in those threads. I posted the "Folder" solution he mentioned.
I think I see what some of the problems here are with us trying to communicate with you if you can't take the time to get it from those threads.
I've always had pretty good luck with MobileMe/iTools/.Mac. I've had it since 2000 and plan on keeping it. Heck I still have like 12 GB open on it. If Google offered 20 GB for free I might consider it but for now MobileMe is just fine. It's too easy and that's why I keep it.
BTW, I think the new Find My iPhone freebie is something Apple should have done from the start. Apparently Android has a similar free feature that spurred Apple to do it. Competition is good!
