DOH!! I guess I shoulda looked into the root directory. Is there a tutorial anywhere that will answer all the dumb questions I have?
Like how to copy a file from one directory to a flash drive using terminal, or to an external hard drive? How do I run a DVD on my machine, millions of seemingly dumb questions have I... how do I boot up with my chosen PC directories as folders on my desktop-lots of dumb stuff
Edited by papabill (11/13/1007:19 PM)
#544251 - 11/14/1006:59 PMRe: Help finding directories
[Re: papabill]
MacGizmo
Moderator
Loc: Arizona
Not sure why you would want to use the Terminal to do something you can do right in the Finder simply by drag & drop, but you can do it with the following command:
According to my Mac, my flash drive is /dev/disk2 249408 110 249298 0% /Volumes/FLASH
I want to copy /etc/httpd/httpd.conf to this device. What is the proper syntax to accomplish this? I've tried cp /etc/httpd/httpd.conf /dev/disk2/httpd.conf, but it gives me this error: cp: /dev/disk2/httpd.conf: Not a directory
I cannot even go cd /dev/disk2, because it gives me the same error. How do I change to that device or to another drive?
You are making this waaay to complicated. Just drag and drop. Shed your old PC habits or you gonna make yourself nuts. Go the easy route for now and then f you wanna be a Mac Geek later you will have some familiarity with the lay-of-the-land.
The drive should be already mounted on your desktop, open it by dbl clikking and open a window for the receiving folder and drag... or select all wanted files and copy paste into receiving folder.
Unfortunately, that does not work. I try cd /dev/disk2s1, and what I get is "-bash: cd: /dev/disk2s1: Not a directory", and cd /usb drive and what I get is -bash: cd: /usb: No such file or directory
Edited by papabill (11/15/1009:03 AM)
I'm lost then. cd /Volumes/(name of flash drive) works here. It appears your drive is named FLASH, so it should be typed exactly cd /Volumes/FLASH There is a space between cd and /Volumes/
Why don't you just use the Finder like three of us have suggested though?
