That's probably the best solution. Using the Folder option in Location Properties works just fine. If one has MobileMe the iDisk shows in the Finder so you just set the path to the folder that you want on your iDisk. WebDAV still works from CyberDuck BTW, they use idisk.me.com instead of idisk.mac.com, but since "Folder" works just fine removing the iDisk option would keep you from having to make changes in the future when Apple decides to change their protocols or naming structure again.
But doesn't that just put it in the folder on your desktop iDisk. Then you have to wait for it to auto sync (which sometimes it doesn't).
"That which I quoted from Reboot might as well be written in the Russian language! I haven't the foggiest idea what it all means nor do I know how to implement it for me on my iMac."
Your attention is invited to the mobileme forum* to review the post I just made down there
It is about to Password or not Password your Public folder. [Which some of you are using for your pictures folder.]
Reboot: Please weigh in if I am in error and thank yew.
*Online Services Do you use MobileMe? Google Apps? Yahoo! and others? Here's your place to talk about them, ask questions, and share what you've learned.
It always worked for me! But no one believed me . . . oh no! Chopped liver I am.
I not only believed you but put it to a successful test. I'm tempted to say what I think of the overall direction this thread took, however, but good manners prevent me from doing so.
