• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mac » Windows and Virtualization » Linux on Mac
Page 4 of 4 < 1 2 3 4
Topic Options
Hop to:
#543195 - 11/05/10 03:04 PM Re: Linux on Mac [Re: Reboot]
John Rougeux Offline
Member # -1
Loc: Louisville, KY
Think Linux will run ok on a Bondi blue iMac 333mhz, 288MB ram, 6GB HD, OSX 10.3.9, CD-Rom tray drive?
Top
#543196 - 11/05/10 03:18 PM Re: Linux on Mac [Re: papabill]
NucleusG4 Offline
Master•Blaster
Loc: Miami, Fl.
G4 AGP on it's way.
Attaboy!!
http://davidbearphotography.com/
Top
#543197 - 11/05/10 03:19 PM Re: Linux on Mac [Re: papabill]
Reboot Offline
Loc: Columbus OH
Originally Posted By: papabill
G4 AGP on it's way. The iMac might just be my Linux machine.
Well praise God, miracles do happen. smile
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#543198 - 11/05/10 03:22 PM Re: Linux on Mac [Re: Reboot]
NucleusG4 Offline
Master•Blaster
Loc: Miami, Fl.
And the G4 was the start of the side mounted door which makes it super easy to access all components inside. Very easy machine to work on..IMHO.
I had 2 G4s.. the first which was the Yikes board..grrr.. and the first dual.. the dual 450 mhz. LOL
Top
#543202 - 11/05/10 04:04 PM Re: Linux on Mac [Re: John Rougeux]
Reboot Offline
Loc: Columbus OH
Most recent Linux versions will run on any PPC, from the 7100 on up. Getting it on there may be the trick.
I think with your machine the link to the debian installer above will install straight from the CD. Yours is considered a New World PPC. Burn the ISO with Disk Utility, but don't open the ISO and mount it, it may corrupt it. Just drag the ISO to DU on the left, highlight it and burn. You'll need to use the CD installer since the iMac won't do DVD.
There is the small CD I linked to above, you download only one 200M file. It boots from the one small CD and then downloads the rest of the parts over the internet. I think I'm going to download the whole DVD installer though as there are different kinds of installs, web server, print server, etc. I'd like to try different ones to see what the difference is and having it local on disc would be a much faster install than over the internet probably. It takes close to 3 hours on the G4.
In your case, those tray loading drives can be flaky so doing the web install may make it easier on the drive though as it is an 8 CD install.
The G4 that I installed it on above is picky as to the video card. The stock card only does 800x600 from a stock install, the driver has to be modified to go higher. I saw some stuff on the debian forums but haven't tried it yet.
I tried a couple of newer video cards to see if it was the older card but then it just booted to console saying "debian couldn't start xserver." That too can be fixed with a driver mod. I tried but it is pretty involved. When I have the time maybe, I'll probably stick with the stock card, it's a 16M ATI so it should be fine, I just want to get the resolution higher.
So to answer your question, yes. grin
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#543203 - 11/05/10 04:45 PM Re: Linux on Mac [Re: Reboot]
papabill Offline
Where's the cache?
Loc: Belmont, NC
Well, I don't like buying things blind, but maybe I'll not get skunked too badly. This is what it says about it:
Apple Power Mac G4 400mHz AGP Graphics Tower Model: M6921, Order Number: M7825LL/A, Machine ID: PowerMac3,1
Features:
Processor: 400mHz PowerPC 7400 v2.9 (G4)
RAM: 768MB RAM
Hard Drive: 20GB ATA Hard Drive.
Optical Drive: DVR Super Drive.
Other Drives: Iomega Zip 100
Graphics Card: ATI Rage 128 Pro w/16MB VRAM, DVI & VGA Connectors
Modem: 56k Modem.
Audio In: 1 - 3.5-mm analog input jack (16-bit 44.1 kHz sample rate)
Audio Out: 1 - 3.5-mm analog output jack, Built-in speaker (16-bit 44.1 kHz sample rate)
USB Ports: 2 - 12 MBit/s
Firewire Ports: 3 - 400 MBit/s (1 internal) (15W total power)
Ethernet: 10/100BASE-T (RJ-45)
Expansion Slots: 3 - 64-bit 33 MHz PCI, 1 - 2x AGP
Software/OS: Loaded with OS X 10.4 Tiger & factory software, ie: Safari, Mail, iTunes, iLife '08 + iMovie '06 (iMovie '08 not compatible) and Appleworks for Word Processing (No disks included).
DOES NOT INCLUDE: Airport Card, Bluetooth, Keyboard, Mouse or Monitor.
Sounds good, anyway.
Top
#543205 - 11/05/10 04:52 PM Re: Linux on Mac [Re: papabill]
NucleusG4 Offline
Master•Blaster
Loc: Miami, Fl.
Hmmm... no boot disks for the Tiger install. I may have one floating around here somewheres....
Top
#543211 - 11/05/10 06:01 PM Re: Linux on Mac [Re: papabill]
Reboot Offline
Loc: Columbus OH
That will work fine. You'll have a much better OS X experience.
Might want to scrape up a little more RAM but that's a decent start. One thing you definitely want to do first before you start installing stuff on it is to install an extra internal drive and clone the system to it using SuperDuper or something in case something breaks, since you don't have any install discs for it. SD does a 1:1 bootable copy of the HD to another HD.
I know I'm pushing it now, but, down the road, the processor can upgraded for around $100 to a faster processor and run Leopard, 10.5.8.
AppleCentral Trivia
MM-MCF Trivia
Call the Doctor
Top
#544067 - 11/12/10 04:39 PM Re: Linux on Mac [Re: Reboot]
EzyriderTX Offline
Zomby Woof
Loc: Dallas, TX
I use my old Beige G3 in my garage as an internet radio server. The iTunes radio tuner sill streams fine. Running OS 9.2.2. I also installed Classilla in case I need to browse the web for something. It all works great. Tried to install Linux back in the day and yeah...way too much trouble. OS 9 runs like lightning on it.
I have an old 400 MHz G4 Digital Audio tower in my computer room that I upgraded the processor on years ago to 1.2 GHz. It is running Leopard and is an excellent file server. Heck the kids still use it to surf the web too. You might want to check out G4 processor upgrades. They are relitavley cheap these days. I think you can even get dual 2 GHz processor upgrades for most of the old G4 towers. Between that and 1.5 GB RAM and a couple of 120 GB HDs in it...not a bad little machine for almost nothing.
Top
#544237 - 11/15/10 01:17 AM Re: Linux on Mac [Re: EzyriderTX]
papabill Offline
Where's the cache?
Loc: Belmont, NC
I might try to put Linux on my iMac Grape (G3-333) if I can figure out how. I really don't need it, but it's something to play with and learn from.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek, MacGizmo, Reboot
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.037 seconds in which 0.021 seconds were spent on a total of 14 queries. Zlib compression enabled.
