However, my monitor DOES NOT plug into that card. It plugs into the connection coming directly from the M/B. In fact, there is nowhere on that card for a standard monitor hookup-just a RA/LA/V RCA connectors for output to a TV.
The mobo connection is that 2M card. Like said above, the card with the RCA jacks is an A/V I/O board, like for capturing video from a camcorder into the Mac via Premiere or something like it, it's not a video out board.
BTW with the 4M chip out mine will still do 1280x1024, but it does back it down to 256 colors. You say you have a chip in the VRAM slot? It's the chip that lays flat next to the RAGE chip. If you do it's a bad chip then as it's not showing up, you would have 6M with it in.
Also like I said, you need to be using some kind of adapter to come from the mobo video out to the VGA connector on the monitor. It may not be the right one, or not set right. Does you're video cable go straight to the mobo, or is there an adapter?
#542819 - 11/03/1008:10 AMRe: Video card for Power Macintosh G3
[Re: Reboot]
MicMeister
Le Skibum & Pixelsmith
I have a 266MHz G3 Desktop in the storage, originally bought in January 99, and I always found the built-in ATI Rage so underpowered with 2megs of VRAM it wasn't even funny*. Then I put a Voodoo3 card (16MB in it), which at the time rocked and made me happy. And was much cheaper than buying more VRAM to the ATI in those days. That's what I'd suggest to Papabill. If you can find one, that is. EDIT: Oops. I forgot you run OS X 10.2 on that thing. IIRC, the Voodoo3 won't work with X, only Classic.
Getting that thing to show 1024x768 rez only gave thousands of colors, which was unacceptable. 834xsomething was the highest it gave with millions of colors, and it wasn't the adapter's fault, but the shortcoming of the built-in video card.
You need to add more video RAM, VRAM. Look at system profiler, it probably is only 2M of VRAM.
It already has a 4Mb chip in it.
If it is in this slot, white u shaped thing, but it only shows 2M VRAM, then the chip is probably bad. But that's not why you can't get to 1280x1024. Believe me, I have the same machine in the desktop version here and with 2M it gets 1280x1024, albeit at 256 colors instead of millions. It the generic adapter you mentioned that is limiting it to 640x480. It is locked in at that res. You can get a cheap adapter that has dip switches to set it for different resolutions. Look around for a DB-15 to VGA adapter.
