Dude,, you really are awesome. I never... never!.. knew you could add vram. (prolly since I always have towers...)
I figured if it was onboard, then it was a fixed amount. After market cards are all fixed.. right? I have never bought a PCI or AGP card that had modifiable vram.
I think it came originally with 2 Mb and there has been a 4Mb chip installed.
How do I find out how much is showing? I cannot find a reference to it in System Profiler. There should be 6Mb, and I should be able to have at least 1024 x 768 (every monitor I hook it up to says only 640 x 480 is available.)
