Move Time Machine volumes to anther drive and have them not lose backups/data. I recently bought a Seagate 500GB Expansion drive (Amazon Lightning Deal for $65). I first tried Disk Utility's Restore function to clone the TM volume from one drive to the new one, but it wouldn't do it, stating that that operation was not allowed (permissions on the new drive?), but the old, tried and true, drag and drop method worked flawlessly. Now, I just need to save up for that 7200 RPM Seagate 250 GB internal drive for the Mini. Still gotta move some things among the drives in prep for that, too.
#539346 - 10/11/1002:28 PMRe: Yes you can!
[Re: Jim_]
As soon as I designated it as the TM volume, it started a backup (incremental) and ID'd it as the previous backup volume with the correct listing of oldest and most recent backups (after the new, incremental bu completed). TM is happy with it.
#539433 - 10/11/1007:04 PMRe: Yes you can!
[Re: MacBozo]
This is interesting:
The DMG (the .sparsebundle) of my wife's TM backup is formatted case-sensitive, journaled. My TM backup is not (not even a .sparsebundle for it). I'm assuming that it is because the volume for her backup is physically attached to my Mini and is accessed over the network from her Mini while my TM backup is directly to the volume attached to my Mini rather than via network access. Is there any problem of formatting the eventual HD that will be her dedicated TM volume (directly connected to her Mini) as Case-sensitive so that I can simply copy the backups.backupdb to it from the mounted disk image?
Don't know about the case-sensitive copying/transferring TM backups from her machine sparsebundle thing though.
Like NG4 mentioned about machine IDs there is some voodoo there, but I have never run across the need, I just start over. I have never felt a need to worry about past data. If in doubt I keep it. :-D
I'm just interested in a fail safe backup from an hour ago with TM, and a bootable day or so with SuperDuper. With my clients no one thinks it's worth the money to transfer, they just want a backup so I haven't had to mess with it.
So like I said I know there is voodoo to doodoo it right. Oddly I just haven't had to yet, so I am interested in your results. Still wondering if yours is backing up from the same point, does the time line for past dates show, and are you able to get to an older date and recover something when you enter Time Machine.
#539483 - 10/12/1007:01 AMRe: Yes you can!
[Re: Jim_]
Yes, time line is intact. I've decided to leave her TM volume attached to my Mini rather than swapping drives between enclosures and moving one to her machine. It's just easier to keep it that way (and fewer questions from the wife).
