Error message on Now Up To Date: -39 #536753 09/23/10 05:54 PM
B
bethben Offline OP
B
I closed Now Up To Date as usual and when I reopened it I received the following message: Unexpected error (unexpected end of file) id=-39. Now Contact opens fine. I also can't open my backup calendar file because I receive the same message. I also tried reinstalling the software but I get the same message. Help?
Re: Error message on Now Up To Date: -39 [Re: bethben] #536843 09/24/10 04:15 AM
Reboot Online Content
Online Content
End of file -39 is a standard corrupt file/database. Try using a backup.
Re: Error message on Now Up To Date: -39 [Re: Reboot] #537449 09/29/10 12:44 AM
B
bethben Offline OP
B
Thanks. I did try and I still get the same message. I tried uninstalling teh software and reinstalling but the error message continues. I'm guessing I need to delete a specific file that is somewhere on my computer but I have no idea what or where.
Re: Error message on Now Up To Date: -39 [Re: bethben] #537643 09/30/10 10:46 AM
Online Content
Look in the ~/Library/Application Support folders, also in the ~/Library/Preferences folder for a corrupt preference file. Maybe even a cache file/folder in ~/Library/Caches.
Don't delete any files, just move them from their original locations.
~ is your users folder BTW, Users/you/Library/...
