#534539 - 09/04/1009:02 AMRe: who's watching the streaming video?
[Re: John Rougeux]
DLC
I invented modding!
Loc: Lilburn, GA
John I tried RipIt but it says it can't rip 40% of the disk. These are DVDs made with a Panasonic DVD recorder from a DVR. Are they in the wrong format? Is there a program that will convert these to H.264 or some format RipIt can use ?
I'm guessing wrong format. The format that exists on a DVD is very different than that from a televised/transmitted show. That has already been compressed and is likely some form of Mpeg 2.
RipIt is for encrypted DVDs only. You should be able to just copy the VIDEO_TS folder from the Panasonic DVD to the computer and work with that.
Are you trying to make copies of the disk, or trying to convert them to some other format.
