So the IT guy at work gave me a 1TB Buffalo Terrastation Pro. It has SCSI, USB, & ethernet connections. I don't think the USB part is to connect via external like normal.
This thing runs some OS on it and I"m not sure if it'll work on my mac.
Can I hook it up via Airport and use it like that as a time machine/iTunes server?
Can I wipe the drive and install MacOSX on it?
Can I change out the drives and then put MacOSX on it?
