carp
Dino's are Babe magnets
Loc: Hawaii
Good suggestions Zwei.
I would go with the camera connection kit for sure. Case like what Zwei said unless your gonna take the iPad out of the house you don't need one - than again how can the iPad get you chics if you don't take it outside
zwei
soporific
Loc: Near an iPad
Pro Tip: Do not worry about screen smudges it will drive you nuts if you try to keep the screen smudge free. I used to hold it by the edges as much as possible when I first got mine. Just grab the thing and go.
