iWeb Forms #528648 07/07/10 10:17 AM
keymaker Offline OP
I invented modding!
I invented modding!
I've got to the point where I need to place interactive forms on my Web site for various purposes e.g. 1. registration of persons wishing to take part in various projects and 2. educational dialogues for the kids trying to lean an academic subject at my site. I've got this book that explains how to make forms using PHP but I don't think iWeb supports the language... so my question is: how do I go about making an interactive form in iWeb? Thanks,
km
Re: iWeb Forms [Re: keymaker] #528663 07/07/10 12:34 PM
Reboot Online Content
Online Content
No first hand experience but this or this may help if no one can help here. smirk
Re: iWeb Forms [Re: Reboot] #528666 07/07/10 01:40 PM
keymaker Offline OP
I invented modding!
I invented modding!
Thanks, I'll check those out. Much to my surprise I got this to work on the input fields but the submit buttons didn't work - which I suppose is where HTML runs out and PHP kicks in:
{form method = “post” action= “docs.php}{pclass= “legend”}Personal information{/p}{fieldset id= “personal”}
{label}Name:{/Label}{input type=“text”
name=“name” size= “30” /}{br /}
{label}Address1{/Label}{input type=“text”
name=“address1” size= “50” /}{br /}
{label}Address2{/Label}{input type=“text”
name=“address2” size= “50” /}{br /}
{label}Town{/Label}{input type=“text”
name=“town” size= “50” /}{br /}
{label}City{/Label}{input type=“text”
name=“city” size= “50” /}{br /}
{label}Postcode{/Label}{input type=“text”
name=“postcode” size= “30” /}{br /}
{p id=“buttons”}{input type=“submit”
value=“Submit” /}{input type=“reset”
value=“Reset” /}{/p}
where { } = < >
km
Re: iWeb Forms [Re: keymaker] #528669 07/07/10 02:34 PM
P
polymerase Offline
P
A complete shot in the dark. You don't have a closing html for the form=method. Stick a {/form} on the end.
Wait, you're using iWeb. iWeb doesn't contain the ability to make forms so you need a third party cgi or javascript. (Which I guess you must be using since you got this far. )
So it could be a simple nonclosing of an HMTL call. Are you using something like BBedit to colorize the HTML? It can be handy for figuring out where the messed up code is.
Re: iWeb Forms [Re: polymerase] #528676 07/07/10 03:21 PM
keymaker Offline OP
I invented modding!
I invented modding!
Thanks - I had the closing form tag in the code but not in my post for some reason - cut and paste error. The actual form looks like this at the moment (below) but as you can see the submit buttons haven't worked. All I did was type up the code in Pages and cut and paste it into an HTML snippet which was obviously over-optimistic!
Re: iWeb Forms [Re: keymaker] #528693 07/07/10 05:51 PM
P
polymerase Offline
P
instead of id="buttons"
try
{input type="button" value="Submit" / }
or, if your code is correct, it could be that the plural "buttons" is tripping it up
so try
{p id=“button”}{input type=“submit”
Re: iWeb Forms [Re: polymerase] #528792 07/08/10 07:10 AM
keymaker Offline OP
I invented modding!
I invented modding!
Thanks, although it didn't seem to work. This is what one bloke says about getting PHP to process iWeb's HTML snippet:
http://www.eden.net.nz/7/20080520/
What does he mean by: "At the root level of my website, I create a file named .htaccess..." ?
km
