..on an iPhone 4 yesterday in the Aventura Apple Store.. with one of their demo phones. I got it drop 1 bar while holding it. You would think they would have a phone out on the floor that wouldn't do that....
#528532 - 07/06/1008:24 AMRe: I reproduced reception problem
[Re: NucleusG4]
six_of_one
Pool Bar
Loc: Alexandria, VA
It's not the phone, it's the signal. Not much the store can do about that, unfortunately. Still not great PR though when your exclusive partner can't even get a strong signal to one of your stores. I wonder what a Verizon signal would be like there?
Uh...it's the phone. Well documented that iPhone 4 loses bars when holding it so that your hand contacts more than 1 antenna at a time. But only on some version 4s... not all. So it would seem that even the Apple store got some of the problematic ones.
See other threads in here about the iPhone 4 losing signal strength when held a certain way.
#528569 - 07/06/1011:45 AMRe: I reproduced reception problem
[Re: NucleusG4]
six_of_one
Pool Bar
Loc: Alexandria, VA
All cell phones can lose some signal when holding them -- it's not unique to the iPhone or even the iPhone 4. If the signal is weak to begin with, holding a phone a certain way can attenuate the signal down to zero, as seen in some of the youtube vids ... if the connection is strong to begin with, it won't matter much how you hold the phone. For instance, at home with my iPhone 4, I can't make the bars go down no matter how hard I try -- even bear-gripping the unit with two hands won't budge the bars. However, if I go to a local coffee stop a few miles away where the signal sucks, it's relatively easy to get the bars to move (although I never lost the connection completely).
Frankly, this isn't much different than moving to another room and losing a weak signal ...
Also, if you just lost a single bar, then you haven't really recreated the debilitating degradation of connection others have been reporting (unless the signal was at a single bar to begin with, in which case see above ;-). Losing a bar or two during a call isn't in any way unique to the iPhone 4 ...
Now, having said all that, Apple has stated that all of their iPhones have so far have been indicating incorrectly strong signals, leading many people to believe just holding the phone will kill a strong signal down to no connection at all, whereas the connection in the first place was actually weaker. We'll see if this is the case when they release their fix in a week or so ...
#528636 - 07/06/1011:06 PMRe: I reproduced reception problem
[Re: six_of_one]
carp
Dino's are Babe magnets
Loc: Hawaii
Right Six, according to Apples open letter to customers.
In my house, I can make phone calls from my bedroom, the second I walk to the front of the house, I lose all bars. Basically a dead phone from the living room to the garage and to the mail box. This is Moby PCS service
Daughters Verizon service, no problems anywhere on property.
Daughters boyfriend AT&T iPhone 4, has problems anywhere inside the house but outside he has no problems <-- go figure. Side Note, I do have wifi, so that single is strong, just phone calling and or reception.
Yeah, I read the letter... and I'm not saying that holding a cell won't cause some signal drop. You are right.. I only lost 1 bar... which isn't indicative of anything.
As one guy says in response to Apples letter..
Apple Press Release Translation: Yeah, it's just a calculation issue with displaying the bars... The dropped calls are just your imagination and/or AT&T's problem.
and another...
This is whats called the Jedi Mind trick, to end all mind tricks. There is...no iPhone issue.
On another note... holding my 3Gs with the case on I can make it drop 1 bar... w/o case I can make it drop 2....
Funny, never had this issue when my phones used to have an antenna outside the phone.
Never had this issue with my RAZR either, the antenna for that is down at the bottom of the phone. Also don't notice it much on my Omnia, the antenna for it is also down at the bottom of the phone, which also happens to be where I hold it.
Then again, I don't have AT&T :P
I'm in a huge building right now...with 5 bars reception. The phone is in it's carbon fiber case.
But as soon as I wrap my two hands around the phone I dropped 3 bars over the course of 30 seconds. Interesting that all that concrete and metal didn't stop those 3 bars... but 2 pounds of flesh did. Maybe it's more the electrical field?
#528872 - 07/08/1003:49 PMRe: I reproduced reception problem
[Re: NucleusG4]
zwei
soporific
Loc: Near an iPad
I also read that dirty hands affect it more than clean ones. (salt, sweat, etc.) which also may have affected the tests in the lab. Everyone is required to wash their hands before messing with them in the labs. ...or so they claim. That maybe the main reason a some people are seeing the problem worse than others too
