I believe some of the time issues like you just experienced as well as maybe even those with issues about their own posts being marked unread is due to the server setup here and I believe Neil is working on a plan to address that.
AppleCentral Forum IT by Mindraven
Quick question. Are the ads still overlapping for those having the issue? Made a couple of changes, so please reply if you're still having that problem.
That has fixed it for me in the Reply windows, seems you're limiting the size of pics in the Reply windows now so that seems to have fixed it.
10.5.8 Safari, no cache cleaning done, it just works now.
Thanks for helping out Rick. I have seen where I Submit on a post and it says that it was a minute or two before I posted. I'm sure that has something to do with the "you can only post every 0 seconds" error in the OP's thread starter.
While you're in the neighborhood, any idea why the smilies are putting a Return before and after themselves? My sentence above had no Returns on my part.
Also we have the ads problem with run on sentences with no spaces. It's easy to reproduce. I'll compose a PM to you with a repeating word with no spaces. I know, why would anyone do that, but it also has happened with long urls. It also shows in the Preview window if you're composing a PM or Reply. Can the text window size be limited in some way?
#528124 - 07/01/1007:32 PMRe: This place is almost unusable...
[Re: RickB]
Nana
I mod in my sleep!
Loc: US
Rick, I am using OS 10.4.11 & Firefox.
I just deleted the caches, restarted Firefox & now the overlapping of ads has disappeared when viewing the forums.
Ads are still overlapping slightly now when replaying to a post. However, the overlapping is not inside the replay box like before. The ads are way to the right now.
#528820 - 07/08/1002:35 PMRe: This place is almost unusable...
[Re: John Rougeux]
MacBozo Nut Dood
Just in the last 2 days, it has gotten really slow again for me. 10 - 15 seconds delay/stall from click to the page begins to load. FF shows "Waiting for www.MacTech.com" during that time.
