Lea is right...you are only choosing what is posted in the Politics section. He has posted in numerous other sections of this forum and has been polite. I'm sure that I could find equally, if not more, offensive posts down in that section. Perhaps I should go down there and start putting the hammer down?
And besides, how is his posts any different than what you put in here to bypass the censor? Does using the F word really make you feel better?
Quick question. Are the ads still overlapping for those having the issue? Made a couple of changes, so please reply if you're still having that problem.
AppleCentral Forum IT by Mindraven
I'd also recommend anyone having the issue, try restarting their browser or doing a hard refresh. You might still have the old stylesheet settings cached and not getting the updated changes.
